mixture multiphase model (convergent-divergent nozzle) |
Anwar
Rep Power: 0 ![]() |
Hello everyone,
I'm doing a simulation for multiphase flow (mixture model) to validate paper’s results. By the way, in the paper, the authors used this setup: - Separation implicit solver. - SIMPLE scheme were applied to resolve pressure-velocity coupling equation. - the k-ε two-equation turbulent model, standard wall functions were employed to the flow in near-wall region. - The second-order upwind difference scheme was also applied to improve the computational accuracy by discretizing the physical parameters of volume control interface. - the convergence precision 10-6 of the residual monitor for energy equation. - a mixture model was selected with inter-phase velocity slip taken into account. - conversion of mass source and energy source were compiled by User Defined Function (UDF) and coupled to flow functions. ( I have problem in this point, so I used evap/cond Lee model) The main problem that I faced is instability in the solution, while I find the under-relaxation factors and evaporation frequency so significant factors in the solution. Hope someone who has the experiences in this can help me. So, please find attached pictures that compares between my results and the paper’s result, and give me your feedback. Regards, Anwar |
Yafei Li
Rep Power: 8 ![]() |
What fluid was used? how to set the density and sound speed of gas and liquid?
mixture model, multiphase |
[swak4Foam] swakExpression not writing to log | alexfells | OpenFOAM Community Contributions | 3 | March 16, 2020 19:19 |
VOF model + mixture model + RAS or LES model | ebtedaei | OpenFOAM Running, Solving & CFD | 23 | May 12, 2018 04:36 |
Convergent Divergent Nozzle | Hrishikesh | Main CFD Forum | 12 | June 25, 2016 03:06 |
mixture model or multiphase model in my UDF? | aleisia | Fluent UDF and Scheme Programming | 0 | June 8, 2011 14:25 |
A question about UDF utility in mixture and multiphase model | aleisia | Fluent UDF and Scheme Programming | 0 | June 7, 2011 17:32 |
