July 1, 2020, 16:55 |
Density for mixture
Yije
Rep Power: 6 |
Hi all,
I am modeling a gas-porous solid reaction. When I used Volume-weighted-mixing-law for the mixture density, all the calculations went fine without any problems. But, when I switched it to Ideal-gas, the calculation stopped with a Floating point exception error. The residuals for the turbulence terms got increased with iterations. What would be solutions to this problem? Thank you, Yije |
density, ideal-gas, mixture |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 15:33 |
Implement simple barotropic relation - derive density field from pressure field | GJM1991 | OpenFOAM Programming & Development | 6 | May 8, 2016 16:43 |
A problem about density in liquid air definition | alloveyou | CFX | 2 | June 14, 2012 15:20 |
REAL GAS UDF | brian | FLUENT | 6 | September 11, 2006 09:23 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
