Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
DPM poor predictions in Hydrocyclone
Old   June 28, 2020, 22:42
Exclamation DPM poor predictions in Hydrocyclone
Gregori
greg93 is on a distinguished road
Hello dear all,
I'm working with multiphase simulations in hydrocyclones using Fluent for my Ph.D. thesis. I have some experience with CFD simulations but I'm still learning about multiphase simulations for solid-liquid interaction. For dilute suspensions, I'm trying to use the one-way coupling, and as the equipment is a hydrocyclone I use RSM to model turbulence. First I start the transient solution with water only. When some responses start to stabilize, such as Pressure Drop and outlet mass flow rates, I enable the DPM in the postprocessing step to release particles from injections. I know that the DPM is very sensitive to parameters such as Stochastic Tracking (in turbulent flows) and I tried to use some standard values as there are no detailed procedures for hydrocyclones in literature. However, no matter what I do I always get poor results for particle collection. For example, In my case particles of 5um should be collected with 50% efficiency, and when I track these particles in the solver I get 96%. For smaller particles, this efficiency reduces but is still around 90%.
Does anyone here has had the same problem when working with DPM? I know that this is a well-known approach but I still can't solve this issue.
I'm using a mesh with 226K elements which is a good size according to the GCI that I calculated. My hydrocyclone is small, with Dc=30mm.
I would really appreciate if you could help with this problem guys. I've been trying to search and study with the Ansys Users Guide and some documents that I found on google but I didn't succeed, and this is an important step in my Ph.D. research.
greg93 is offline   Reply With Quote
dpm, hydrocyclone, particle injection, turbulence
Confused between DPM and multiphase flow pchoopanya FLUENT 0 June 21, 2019 05:44
DPM mass flow kingpots FLUENT 0 November 29, 2012 23:20
Dpm injection mass flow rate diamondx FLUENT 0 November 22, 2012 14:04
DPM injection mass flow rate kingpots ANSYS 0 November 22, 2012 12:12
slow after mesh for enhanced wall treat DPM joshkemp FLUENT 0 May 1, 2007 18:20
