Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Large global courant number and small residuals
Old   June 19, 2020, 18:31
Default Large global courant number and small residuals
Wenying
PotatocatIL is on a distinguished road
Hi all,
I'm simulating transient two-phase flow (liquid-vapor) in a cylinder-shape separator. This is a try-run with Eulerian-eulerian model + Multi-Fluid VOF model+ Implicit Fomulation+ Sharp type interface modeling because I'm trying to get both the flow path of droplets and the separation of two phases. Also, for the viscous model, I used realizable k-e +standard wall functions and calculate the turbulence per phase. (I know it's a lot of calculation...)
The thing is: when I use the adaptive time step and set the global courant number= 400 (The default setting is 800). It seems I have a really small time step (1e-5 s) while the residuals are all small (1e-10 to 1e-4). Is this normal? Can I further increase the global courant number?
Thank you in advance!
Potatocat
PotatocatIL is offline   Reply With Quote
two-phase flow
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' BrendaEM OpenFOAM Meshing & Mesh Conversion 12 April 3, 2022 19:32
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
