Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Surface tension modelling
Old   June 6, 2020, 23:08
Default Surface tension modelling
Anshuman Sinha
Anshs is on a distinguished road
I am modeling multiphase flow, with water (green) , oil (red) , air (blue). The water is flowing through the oil, but I am having results where the air is coming in between water and oil. and separating water and oil. I think it's because of surface tension modeling.
Why is the air coming in between water and oil? Thanks
phases:
Surface tension modeling:
Anshs is offline   Reply With Quote
Old   June 9, 2020, 02:17
rupak504's Avatar
Lolita
rupak504 is on a distinguished road
phases:
Attachment 78220
Attachment 78221
What's the outlet boundary condition?
rupak504 is offline   Reply With Quote
Old   June 9, 2020, 09:53
Anshuman Sinha
Right side, you may like to refer to this figure:
Old   June 10, 2020, 16:05
rupak504's Avatar
Lolita
Attachment 78264
The air might be coming in between water and oil due to entrainment.
fluent, multiphase, surface tension model
Help!! customize surface tension term in interFoam w051cxw OpenFOAM Programming & Development 5 February 12, 2016 15:56
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
surface tension gradient using UDF; surface tension gradient as function of temperatu marimuthusundar Fluent UDF and Scheme Programming 0 June 21, 2012 05:48
Surface Tension Test Cases sega OpenFOAM Running, Solving & CFD 2 March 8, 2011 13:19
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 04:41
