VOF, Boiling, When surface tension = f(T), Spurious currents appears |
June 6, 2020, 04:19 |
Lolita
Rep Power: 10 |
hello,
I am simulating a pool boiling problem, I am using the VOF method and inbuilt phase change module. It works fine, but a soon as I use surface tension as a function of temperature, spurious currents appear at the interface 11111.PNG. any help would be highly appreciated |
June 7, 2020, 10:04 |
Surface Tension Modeling
This is an artifact of surface tension modeling, usually with CSF approach. Try using CSS instead. Furthermore, if Ca is very low, you might require very fine mesh or LSM so that curvature is predicted correctly for surface tension modeling.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 9, 2020, 02:14 |
#3 | |
Lolita
Rep Power: 10 |
surface tension problem when using VOF+Solidification&melting models | AlvinF | FLUENT | 4 | April 22, 2024 11:31 |
VOF - Eliminating shear on the surface of a thin liquid film | saisanthoshm88 | Fluent Multiphase | 0 | October 27, 2013 13:22 |
continuum surface tension model | yukn | Main CFD Forum | 0 | October 8, 2011 07:43 |
modeling pipe flow with strong surface tension | phsieh2005 | OpenFOAM | 0 | August 27, 2009 14:51 |
VOF method +surface tension | yapalparvi | OpenFOAM Running, Solving & CFD | 5 | July 17, 2009 04:56 |
