Eulerian Multi-Phase Fluidized bed convergence |
June 5, 2020, 06:16 |
arif
Rep Power: 9 |
I didn't take convergent results whatever i tried in eulerian multi-phase flow. Mesh quality is enough in terms of skewness and orthogonal qualities. I have problem about continuity eqn convergence. If any possible advice such as time step, under relaxation or scheme, i will be appreciated greatly.
June 5, 2020, 07:39 |
Flow Description
The description of your case is rather vague and very generic. Assuming the mesh is good, the problem could be in physical setup. Numerics, such as, URF or time-step would help only if the physical setup is correct. Otherwise, doesn't matter what time-step or URF you use, the case will keep on diverging. You need to share more details of the setup, such as, material properties, boundary conditions, phase interactions, etc.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 5, 2020, 07:52 |
arif
Rep Power: 9 |
Model: Eularian Granular Multi-Phase
Phases: Air and Sand Inlet B.C: Velocity Inlet Outlet: Pressure Outlet Wall: Specularity Coefficient as 0,6 Laminar 2-D Implicit phase coupled Pressure: Tried PRESTO and second order Volume Fraction: First Order Least Square based I tried initiliazation from fluent user guide tips Time Steps: 0,001, 0,0001, 0,00001 URF: I tried different urf for momentum and pressure. Not exact convergent results I tried variable time steps so i had floating point. I have always floating point exception after some iteration while changing time step. Geometry has conical section at the bottom. Drag Model: Gidaspow |
June 5, 2020, 07:58 |
Flow
Why is the flow laminar? Air cannot even move sand if laminar.
June 5, 2020, 08:04 |
arif
Rep Power: 9 |
I tried turbulence and i had same error. There are a lots of laminar cases in multiphase simulation while simulating sand and air. But i will try again for turbulence.
July 5, 2020, 12:33 |
#6 | |
George Corner
Rep Power: 10 |
apply k-epsilon model then follow the below procedures 1, 2 and 3: 1-model>multhiphase>phases>secondary phase (solid phase)> Diameter: [your desire size] granular viscosity: Gidespaw or syamlal O'brian granular bulk viscosity: lun et al. frictional voscosity: Schaefer Angle of internal friction: leave it by default frictional pressure: based-ktgf fractional modulus: derived frictional packing limit: by default granular temp: algebraic solid pressure: lun et al. radial distribution: lun et al. elasticity modulus: derived packing limit: 0.63 [packing limit can be increased or decreased by yourself. maximum packing limit can be 0.74 also. the high packing limit prevent particles to jump and leave the bed immediately] 2- model>multhiphase>phases>phase interaction> drag choose: Gidespow or syamlal O'brien. [if you choose Gidespow on granular viscosity then you must choose Gidespow for drag also. these two must be same] 3- solution methods scheme: phase couple simple gradient: least squred... momentum: second order upwind volume fraction: Quick turbuetn kinetoc: first order turbulent diss: first order transient formulation: second order implicit Good luck Quote:
expansion of bed in fluidized bed | achy7pch | FLUENT | 7 | August 10, 2024 04:33 |
Diameter of secondary phase in Eulerian eulerian model | user9 | Fluent Multiphase | 1 | May 1, 2020 16:09 |
CFD-DEM simulation of fluidized bed | nkidol08 | Fluent Multiphase | 0 | February 23, 2017 08:47 |
Eulerian phase diameter-importance? | hwet | Fluent Multiphase | 9 | November 22, 2015 05:47 |
Fluidized bed simulation VS particle tracking | windhair | CFX | 2 | June 28, 2011 22:10 |
