Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
heterogeneous surface reaction fluent
Old   May 31, 2020, 08:59
Default heterogeneous surface reaction fluent
Shahin
shahin1 is on a distinguished road
Hi everyone
I am very new to modeling reaction in ANSYS fluent and I can really use any help and guide (even very basic) you can tell me regarding my problem.
I have to simulate a reaction (electrochemical reaction). It is basically a pipe in which CO2 is flown and on the walls it reacts with H+ ions and electron to form formic acid in liquid form.
From the studies I had I got the following notes (please correct me if I have some errores:
1. I have to use surface reaction since my reaction only happens on the walls
2. I have to use a UDF since it is a heterogeneous reaction
and I have these question:
1.As I do not have any knowledge of C, how long it would take me to learn sufficient C programming to write a UFD?
2. The H+ hydrogen ions are in liquid solution with a specific concentration, is it possible to incorporate it in ansys?
sorry if my question is very basic and maybe wrong, please feel free to give me any information or even simpler solution (even if not very accurate) to this problem.
Thanks in advance
shahin1 is offline   Reply With Quote
Old   May 31, 2020, 09:50
Default Electrochemical Reactions
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Fluent has inbuilt modeling capability for electrochemical reactions. You don't need a UDF, until and unless the inbuilt capability doesn't suit your requirement, which doesn't appear to be the case. You have to enable Species Transport, then Volumetric Reactions, and as soon as you enable the latter, Wall and EC reactions show up. Just enable those, provide material and reaction kinetics, and you're good to go.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 31, 2020, 20:15
Shahin
Thanks a lot!
I will definitely go for it, but as my reaction happens on the surface of the pipe (basically they are electrodes, will volumetric reaction be suitable?
Old   June 2, 2020, 09:21
Default EC Reaction
vinerm's Avatar
Vinerm
You can have EC reaction at the wall.
Regards,
Vinerm
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
particle surface reaction fkuwo FLUENT 0 August 14, 2009 12:04
Surface Reaction Model or Heterogeneous Rxn Model? satheeskannan FLUENT 0 September 2, 2008 19:55
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
