Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Mass conservation in evaporation/condensation sim
Old   June 18, 2020, 05:09
Michele
CFD_Michele is on a distinguished road
Originally Posted by vinerm View Post
You might have used temperature boundary condition, however, you need to observe the heat being transferred to the liquid. If the heat transferred is not enough for the evaporation, then it will not evaporate. Also ensure that the material properties are given correctly, especially, enthalpies for liquid and vapor. It is their difference that is important and not their actual values.
Expansion of vapor is important since it requires that much space to be available. If the system is open, then it can flow out. However, if the space is closed, then vapor must be modeled as ideal gas.
Material properties are not easy to find. First because I defined a LPG material, so as to avoid using propane and n-butane separately Secondly because Fluent gives the vapour properties but not the liquid one (that are not easy to find on the web). Do you have some suggestion about finding LPG properties?
My system is open, it consists of an inlet pipe, a radiator and an outlet pipe. I used to extend pipes in order to avoid issues at the boundaries, in this case both pipes are extended 40 times the diameter.
CFD_Michele is offline   Reply With Quote
Old   June 18, 2020, 06:36
Default Material
  #22
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
I am sorry, but I have never worked with LPG, so, I don't have those properties. I suppose it would be easier to find properties of its constituents and then calculate based on mass fractions.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   December 10, 2020, 09:20
Lorenzo Mazzei
Mazze[ITA] is on a distinguished road
Hi guys,
I am having the same issues. Did you find a solution for the mass imbalance? My impression is that, for some reason, the mass transfer rate is unbalanced towards the condensation rather than the evaporation.
Mazze[ITA] is offline   Reply With Quote
Check for mass conservation shuuyaan Fluent Multiphase 9 April 10, 2020 13:48
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate MSchneid Fluent UDF and Scheme Programming 3 February 23, 2019 07:00
Can FVM have mass sinks/ mass conservation problems? whuup FLUENT 0 March 8, 2014 19:48
lost of mass conservation jjchristophe FLUENT 0 June 18, 2010 06:44
Mass Conservation in LES Jaswant Main CFD Forum 8 July 4, 2005 23:32
