May 19, 2020, 16:03 |
Multiphase Simulation of heat pipe
Sai
Rep Power: 6 |
This is sai I am doing a project on heat pipe working fluid is water and it’s simulation in Ansys fluent I have choose VOF model and then regarding the boundary conditions I have doubt. I was supposed to do experiment using **watt as input to it and then calculating the temperatures at some points but by using simulation can I do it ? What all boundary conditions need to be given is heat flux to be given as boundary condition?Then after that I have problem with volume fractions I want to find volume fraction contours of both steam and water.Can some one please help me with this If any one has done project on this reply to this.Thanks IN advance.Please!�� |
May 20, 2020, 04:53 |
Clarity
The description you have given is not very clear. It would be better to use some images or sketches to show the problem you are facing.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Nusselt number or heat flux along a pipe wall | argenisbnl | ANSYS | 6 | December 14, 2018 19:25 |
Heat pipe simulation | bensonnggl | CFX | 17 | September 3, 2017 21:42 |
Heat pipe simulation in CFX | abymathew | CFX | 1 | November 3, 2015 18:31 |
simulation of heat pipe (evaporation part) | DanielLai | FLUENT | 0 | November 5, 2011 11:26 |
FEA Simulation of heat pipe | bensonnggl | ANSYS | 0 | September 25, 2010 01:59 |
