Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
cyclone particle remain in the domain
Old   May 19, 2020, 15:33
Default cyclone particle remain in the domain
mohamad ali mirzaei
mohamadalimirzaei1994 is on a distinguished road
I am simulation a cyclone with large particles (2mm) using DDPM. the problem is that particles tend to remain in the cylindrical part and most of the particles do not go to the conical part and just spin around in the cylindrical part (as it can be observed from solid volume fraction fig attached). I tracked the mass of particles in the domain and it is constantly increasing meaning that particles just remain in the body although the simulation is run for a long flow time (the 20s), and most of the particles have high residence time. Do you know what can cause such a problem??
mohamadalimirzaei1994 is offline   Reply With Quote
Old   May 19, 2020, 16:14
Default Gravity
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Particles are tracked based on net force and one of the important force is gravity. If gravity and operating density are not set, then particles will stay within the cylindrical chamber.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 19, 2020, 19:00
mohamad ali mirzaei
gravity is on and the density of inert particles is specified as well, but still having the problem. I guess in cyclone downward motion of particles is mostly due to the downward gas flow near the wall, not just gravity.
Do you think setting restitution coefficient to below one (for example 0.9) might solve the issue??
Old   May 20, 2020, 04:49
Default Operating Density
vinerm's Avatar
Vinerm
Gravity requires operating density to be set. And if density of continuous phase is lesser than the density of particles, then the density of continuous phase should be used as operating density.
Regards,
Vinerm
Old   May 20, 2020, 07:06
mohamad ali mirzaei
is operating density, the one that is specified in reference values? this value is set based on continuous phase density.
Old   May 20, 2020, 07:12
Default Operating Parameters
vinerm's Avatar
Vinerm
The values in the Reference Values have no effect on the case. The operating density is under Operating Conditions where operating pressure, its location, and gravity is set. You can see it under Boundary Conditions and Cell Zone Conditions.
Regards,
Vinerm
Old   April 22, 2022, 04:36
hossein
hossein76 is on a distinguished road
Hi, I want to do a 4-way coupling in Fluent. Can you help me? Thank you.(cyclone)
hossein76 is offline   Reply With Quote
Old   May 25, 2022, 07:39
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
I can help with your 4-way coupling cyclone simulation
alain.islas@gmail.com
alainislas is offline   Reply With Quote
cyclone separator, ddpm, dpm
UDF for particle interception with pt_termination fortran routine abcdefgh CFX 6 October 6, 2019 14:30
Can solidParticle trap the particle in the computation domain? Ya_Squall2010 OpenFOAM 0 May 13, 2013 04:34
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Particle tracking prob, urgent. sakurabogoda CFX 1 March 11, 2013 22:11
the separated particle temperature in cyclone mkuswadi FLUENT 0 December 17, 2003 09:25
