Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Leidenfrost Effect along with phase change
Old   May 11, 2020, 19:27
Default Leidenfrost Effect along with phase change
rupak504's Avatar
Lolita
rupak504 is on a distinguished road
hello,
I wanted to know if it is possible to simulate the Leidenfrost Effect with phase change using the VOF method in the ANSYS Fluent.
regards
rupak504 is offline   Reply With Quote
Old   May 12, 2020, 04:58
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
As such, Leidenfrost effect is included in Wall Boiling Models. However, if you want to model a hovering droplet, then you will have to use VOF with your own heat and mass transfer UDF.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Multiphase solvers and non-isothermal phase change erlend_grotle OpenFOAM 1 September 25, 2021 10:48
Phase Change >> which solver ? >> met a problem I can't solve, please help me with it Kummi OpenFOAM Programming & Development 6 September 8, 2021 05:58
What are ways to reduce the time taken by fluent and meshing process in phase change. ~Akshay350~ FLUENT 0 March 23, 2017 13:39
Need help regarding phase change models in ansys fluent diggee Fluent Multiphase 0 October 11, 2016 12:35
Change phase phenomena Imane FLUENT 0 May 4, 2016 16:56
