Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Multiphase setup for Rocket nozzle simulation
Old   May 10, 2020, 09:42
Red face Multiphase setup for Rocket nozzle simulation
Shashwat
Legolas_1204 is on a distinguished road
I am an undergrad student. I am doing a fun project to simulate the rocket nozzle. I understand that to properly simulate the system, I have to use the multiphase model. First phase would be liquid propellant(which is RP-1 in my case) and second phase would be exhaust gases. I am very new to this concept so can someone please help me with it? I have searched lots of youtube videos and articles but couldn't find quite what I needed.
Thank you in advance for reading all this!
Legolas_1204 is offline   Reply With Quote
Old   May 10, 2020, 13:26
Default Objective
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What is the objective of the simulation? If it is flow of products through the nozzle for studying the nozzle, I'd recommend not to go into multiphase since you are new to this and heterogeneous reactions could be difficult. If you want to study combustion of liquid propellant and oxidizer, then you have to look at the conditions at which reactions occur. If it is near critical conditions, which is the case for most cryogenic systems, then it is not multiphase but real-gas modeling that you need.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   May 10, 2020, 14:30
Shashwat
Thank you so much. I only want to simulate flow of the products through the nozzle. So, I guess I'll just simulate the flow. Just to be sure can you check the boundary conditions?
Pressure inlet: 3-5 bar pressure, 1200K temp
Pressure outlet: 0.7-1 bar pressure, 260-300K temp
I haven't finalized boundary condition yet as I have to calculate theoretically but it will be in this range mostly... Are they right? I have seen papers with inlet pressure vary from 2 bar to 200 bar so I am confused about it.
Thank you in advance.
Old   May 10, 2020, 14:46
Default Boundary Conditions
vinerm's Avatar
Vinerm
Yes, the boundary conditions are alright. The values depend upon the conditions you want to simulate for.
Regards,
Vinerm
Old   May 11, 2020, 01:46
Shashwat
Thank you so much
Translation motion not working correctly in Eulerian Multiphase simulation (V.11_02) Mikel Valderrama STAR-CCM+ 2 May 13, 2019 07:33
Multiphase Simulation of 26ft planning hull lucasiervolino FLUENT 0 September 27, 2015 18:54
2D Nozzle vapor simulation xof5006 FLUENT 0 December 18, 2012 22:51
Help needed to setup CD nozzle exhausting to atmosphere sangrampp FLUENT 10 January 27, 2011 12:06
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
