Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Diameter of secondary phase in Eulerian eulerian model
Old   May 1, 2020, 09:32
Default Diameter of secondary phase in Eulerian eulerian model
anuj
user9 is on a distinguished road
I am simulating 2-D axisymmetric miniature channel. I WANT TO STUDY AIR - WATER SLUG FLOW WITHOUT PHASE CHANGE.
IDEALLY FOR SLUG FLOW WE SHOULD USE VOF MODEL.
But I want to use EULERIAN - EULERIAN model where it asks for DIAMETER OF SECONDARY PHASE which is air in my case.
By default it takes 10^(-5) m .
user9 is offline   Reply With Quote
Old   May 1, 2020, 16:09
Default Length Scale
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
If the flow morphology is slug or segregated, you won't get good results with Euler until and unless the mesh is very fine. As far as length scale is concerned, you can use a size comparable to expected slug. A smaller size will cause over-interaction between phases and diffuse more momentum than otherwise expected.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Two-phase flow _Problem with phase diameter divergence esma Fluent Multiphase 1 January 8, 2020 15:51
Mass balance for eulerian model with thermal phase change hamed.majeed Fluent Multiphase 1 February 13, 2019 09:11
Secondary phase in Eulerian model hamed.majeed FLUENT 0 October 10, 2018 12:59
Diameter variation eulerian model alekso FLUENT 0 April 5, 2012 13:25
Two phase Eulerian Model Problem senthil FLUENT 5 May 21, 2003 03:55
