Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Eulerian-Eulerian turbulent two-fluid model is not converging?
Like Tree6Likes
Old   April 21, 2020, 17:27
Default Reference
  #21
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Are you talking about the first paper you mentioned, by Ofei and Ismail? That's a fairly simple work. Are you sure you are using correct geometry for the flow rates mentioned. Secondly, you need to ensure that mesh is not fine but coarse enough that it is always larger than the largest particle size. Secondly, they have applied free-slip for the granular phase. Otherwise, the simulation is straightforward.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 21, 2020, 19:13
Min Zhang
minzhang is on a distinguished road
Yes.
I think so.
I think my mesh is fine.
I checked the Details of "Mesh", I only found "Minimum Edge Length" = 0.32358m. My particle size is 270microns=0.00027m.
In addition, when I did the meshing, I used "Inflation" and "Body sizing". For Body sizing, I put the element size 0.0081m. For details, please see the attachment.
Yes. I used the free-slip wall condition boundary for the granular phase.
I chose "Specified Shear" and put all the components of Shear Stress zero.
Thanks again for all your help!! Very appreciated!!
minzhang is offline   Reply With Quote
Old   April 22, 2020, 03:59
Default Mesh
  #23
vinerm's Avatar
Vinerm
Try with a coarser mesh first. Minimum edge length is the smallest length in your geometric model. It has got nothing to do with the mesh. This is only an information provided by the Meshing tool so that user knows the smallest size of the edge and uses a mesh size smaller than that. Do NOT use a very fine mesh. A coarser has better chance of convergence.
minzhang likes this.
Regards,
Vinerm
Old   April 22, 2020, 13:20
Default How could I check my mesh size statistics?
  #24
Min Zhang
Except for my settings in both "Inflation" and "Body Sizing", I did not find any info on my mesh size statistics, such as, Max./Min. face area, Max./Min. cell volume, Max./Min. cell edge length.
Thanks!
Old   April 22, 2020, 14:13
Default Mesh Info
  #25
vinerm's Avatar
Vinerm
That information can be checked within Fluent. Just click on Mesh Check or issue command
me ch
This will list maximum and minimum volume. Similarly, Mesh Quality in Fluent will report minimum OQ and maximum AR.
Regards,
Vinerm
Old   April 23, 2020, 14:21
Default Converging with a coarse mesh, then what?
  #26
Min Zhang
Hello vinerm,
Thanks all your help!!
As you said, it is converging with a coarser mesh. Please see the attachments.
I am using a very small deltaT = 1e-5s. So it will take quite long to finish.
After it finishes the run, I will check the results to see whether it makes sense.
So it means that my settings should be fine, right?
Then, if I want to use a fine mesh, I need to use a much smaller time step?
Old   April 24, 2020, 05:13
Default Discretization
  #27
vinerm's Avatar
Vinerm
Mesh is about discretization in the space and time-step is about discretization in time. If the spatial discretization is fine, so should be the temporal one. So, if you use fine mesh in space, you would require fine mesh in time as well, i.e., a smaller time-step.
minzhang and tudy like this.
Regards,
Vinerm
[swak4Foam] swakExpression not writing to log alexfells OpenFOAM Community Contributions 3 March 16, 2020 19:19
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 22:16
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 14:57
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
