Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Volume fraction
Old   April 16, 2020, 13:05
Default Volume fraction
Rohan
rohan@123 is on a distinguished road
I am analysing material flow behaviour of a plate in which a tool is rotating and mixing the two fluids (the two parts of the plate here being considered as two fluids).
So, what should be the method(coupled/ simple/ simplec/ etc.) and solution controls (value of momentum, pressure, density, volume fractions etc.) to use in the solver?
Again what should be the typical value of the courant no. and volume fraction courant number in multiphase flows?
And should I use steady or transient method for this type of simulation?
rohan@123 is offline   Reply With Quote
Old   April 16, 2020, 14:01
Default Description
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You description is not very clear. A plate as a fluid is rather vague. Could you describe in more detail, may be using a few images?
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 16, 2020, 14:18
Rohan
Kindly see the problem statement. (Attached.).
Looking forward to responses in my trailing questions.
Old   April 16, 2020, 14:22
Default Fsw
vinerm's Avatar
Vinerm
This appears to be friction stir welding. You can refer the following
https://www.sciencedirect.com/scienc...38785418309268
Regards,
Vinerm
Old   April 16, 2020, 14:25
Rohan
But he is using for similar materials. But in my case it is of dissimilar materials i.e. of steel and Aluminium. So what methods and solution controls should I use?
Old   April 16, 2020, 14:28
Default Species Transport
vinerm's Avatar
Vinerm
Since both the materials are in liquid phase and miscible, you have to use a species transport with two components.
Regards,
Vinerm
Old   April 16, 2020, 14:30
Rohan
Sir I didn't understand. Can you pls elaborate what to do and how?
Old   April 16, 2020, 14:44
vinerm's Avatar
Vinerm
Fluent, and most of the CFD tools, have a model called species transport or multicomponent model. This is different from multiphase models, such as, VOF, Euler-Euler, DPM, etc. Species transport assumes that the components are mixed at molecular level, like oxygen and nitrogen in the air. But their fractions can vary. So, if in your case, the liquids can mix, then you should enable species transport model. Look at the following
https://www.afs.enea.it/project/nept...ug/node512.htm
Species transport is compatible with multiphase models, so, you can have both species transport and multiphase together. Species transport will model two liquids as one mixture and multiphase model will model two phases, one represented by the mixture of two liquids and the other could be air around it.
Regards,
Vinerm
#ansysfluent #multiphase
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 12:44
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
mpirun interFoam very stable --> then blows up ghadab OpenFOAM Running, Solving & CFD 3 October 27, 2013 11:34
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 07:17
