Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
reporting DPM velocities and position each time step
Old   April 9, 2020, 14:21
Default reporting DPM velocities and position each time step
mohamad ali mirzaei
mohamadalimirzaei1994 is on a distinguished road
I am doing unsteady DPM modeling releasing many particles in the domain and I need the position and velocities of each particle at each time step tp be written to a text file so I can analyze it using Matlab. current position reporting provide such file only for the last time step but I need file reporting positions and velocities for each time step. can anybody help me??
mohamadalimirzaei1994 is offline   Reply With Quote
Old   April 9, 2020, 14:54
Default Sampling
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Enabled Discrete Phase Sampling under Reports. This needs to be done before you start the simulation and then needs to be stopped once the simulation is done.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 30, 2020, 09:21
mohamad ali mirzaei
I guess this method only reports particle hting specific surfaces not all particles in the domain. am I right?
Old   April 30, 2020, 09:22
Default Particles
vinerm's Avatar
Vinerm
Yes, this depends on the particles hitting the surface you select for sampling. User can also select interiors and then will get information about most of the particles but still not all. If you want information about all, then sampling is not the option to go. Then you export particle tracks.
Regards,
Vinerm
dpm, report
HronTurekFsi3 foam-extend3.1 Maimouna OpenFOAM Running, Solving & CFD 112 April 20, 2019 22:11
How to show the transient case? H.P.LIU Phoenics 7 July 13, 2010 05:31
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
