Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
absolute pressure
Old   April 5, 2020, 03:25
Default absolute pressure
beh70 is on a distinguished road
hi
do u know about ideal gas
how do i define absolute pressure?
beh70 is offline   Reply With Quote
Old   April 6, 2020, 09:19
Default Pressure
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Fluent has an operating pressure value under Operating Conditions panel. Set it to 0 whenever you use ideal or real gas. Then, any value given at initialization or boundary panel is absolute pressure. So, ensure that the value is always positive.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 8, 2020, 04:25
Default Convergent Answer
vinerm's Avatar
Vinerm
I could not understand what you mean by convergent answer. And I recommend using Forum instead of PM because firstly I could be corrected if I am wrong, secondly Forum is meant for learning and others can learn only if discussions are in the Forum.
Regards,
Vinerm
Regarding determinng the absolute hydrostatic pressure for air+water flow in a closed er_ijaz OpenFOAM 0 September 18, 2018 01:11
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
forcesCoeffs - how to use relative pressure instead of absolute pressure WhiteW OpenFOAM Running, Solving & CFD 2 December 22, 2015 13:40
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
about large minus absolute pressure richard FLUENT 3 December 6, 2003 10:39
