Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Error in Histogram plot of Mass Flow Rate
Old   April 2, 2020, 12:14
Default Error in Histogram plot of Mass Flow Rate
Raj
Rajkool is on a distinguished road
Hello Everyone,
I have a model with Multiple inlets and Outlets. I wanted to plot the Mass Distribution of Outlets in Histogram. But when I was loading the file in the Trajectory Sample Histograms.
It was showing some error like "Reading sample file...
Read_Sample_Section: error reading history header from the file, giving up."
I also want to tell you that by default it was asking for .dpm format. But, I have the .out format. I hope this is not a problem.
Please help or suggest any answer.
Thank you
Raj
Rajkool is offline   Reply With Quote
Old   April 6, 2020, 06:18
Default Histogram
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
The option that you are using is meant for DPM only. There is histogram option under Plots that you can use for histogram of Eulerian fields.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 6, 2020, 08:26
Smile
Raj
So, you mean we cannot use the histogram plot for VOF models?
As I have mentioned, I have multiple outlets. I want to check and compare the mass flow of individual outlets and plot on the histogram.
But, the problem is I have a single named selection for all the outlets.
I hope I made some point. Please let me know if I could provide any other info for helping me.
Thank you
Old   April 6, 2020, 08:32
Default Histogram
vinerm's Avatar
Vinerm
You can but not the one you are using. There is another histogram within Plots.
Regards,
Vinerm
Old   April 6, 2020, 08:46
Smile
Raj
Yeah, I have tried it, but I couldn't find the Mass flow option.
Moreover, if I choose, it provides the parameter on one abscissa and another one with no. of outlets. I need a flow a mass flow vs each outlet.
It does not matter, even if it is not the histogram. I just want to know what is the mass flow for each outlet individually.
Thank you once again for fast response.
Old   April 6, 2020, 08:48
Default Mass Flow
vinerm's Avatar
Vinerm
Histogram can be used only for field variables or CFFs (may be also for expressions) and plot the distribution over mesh faces on a particular boundary. What you appear to be interested in is integral flow though multiple boundaries. For this, you have to plot histogram outside. You can report values under Fluxes as well as under Surface Integrals.
Regards,
Vinerm
Old   April 6, 2020, 12:20
Post Expecting Individual Values
Raj
Yeah, I have tried and looked it into Console. But, I am getting the result for overall outlets. (You can see in the Net Value).
I need value for all outlets separately. (I have used a single named selection for all the outlets).
Can you tell me, by using the "Per Surface" option? Can I get, what I am expecting?
Thank you
Raj
Old   April 6, 2020, 12:28
Default Outlet
vinerm's Avatar
Vinerm
That's because you have defined all outlets under one name. All you need to do is separate the outlet. Go to Domain > Zones > Separate > Faces. Select Region and then select the outlet. Click on Separate. It will separate all the outlets into multiple. Then you can report the mass flow rate for all of those.
Regards,
Vinerm
Old   April 7, 2020, 07:57
Default Can I plot histogram to compare them?
Raj
Hello Vinerm,
Thank you, the outlets are separated. In Fluent, can we plot them by comparing each other outlets in a histogram or other graphs with their outlet names on coordinates or axes?
Old   April 7, 2020, 08:04
Default Histogram
vinerm's Avatar
Vinerm
Histogram in Fluent is meant for field variation not variation across boundaries. You have to do that externally.
Regards,
Vinerm
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 09:38
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Mass flow rate boundary condition with negative values ashtonJ CFX 3 November 26, 2014 06:21
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 06:55
