March 24, 2020, 09:25 |
High-Storage for Disk-Space with Fluent Data
Raj
Rep Power: 6 |
Hello everyone,
I am dealing with the VOF model with multiple inlets and multiple outlets. I have given 4000 iterations and an Auto-save option with 5 iterations per each time. It occupied a space of 1.75TB(Terra Bytes), which is too high for disk-space. Please share your ideas and suggestions if possible? Thank you Kolkundi Rajesh |
March 24, 2020, 09:45 |
Intermediate Files
Five iterations per time-step may be too less for convergence. As far as files are concerned, the frequency for automatic saving is decided by user. You should save files every 50 or 100 time-steps, depending upon what the time-step value is. By default, Fluent saves every time-step. With 100, the total space requirement will reduce 100 times. Better option is to save .cdat file, i.e., CFD Post Compatible Files. Those are quite small in size.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
March 24, 2020, 17:39 |
Raj
Rep Power: 6 |
Hello Vinerm,
Thanks for the reply. If it is possible by words, Can you please explain how to create .cdat file? And the auto-save is the only reason to get this storage problem or else there are also other reasons to consider? Have a good day Raj |
March 25, 2020, 04:28 |
cdat and auto-save
To write CFDPost compatible files (.cdat), you need to use File > Export > During Calculation. You can also access it from Calculation Activities.
As far as storage is concerned, you have to check which directory is using most space. If you save data every time-step, then it is sure that Fluent files will fill your drive.
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 05:16 |
High Storage File of Fluent Data | Rajkool | Hardware | 2 | March 24, 2020 17:43 |
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) | Aadhavan | OpenFOAM Meshing & Mesh Conversion | 2 | March 8, 2018 02:47 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 06:38 |
[Commercial meshers] Problem converting fluent mesh | vinz | OpenFOAM Meshing & Mesh Conversion | 28 | October 12, 2015 07:37 |
