March 10, 2020, 15:29 |
water jet impingement
Rep Power: 7 |
I'm trying to simulate water jet impingement. When the water exit the nozzle it suppose to hit the plate , however In my simulation the flow reverse.
I have inserted the gravity effects. any suggestion ? please see thee picture below |
March 10, 2020, 16:25 |
Direction of gravity vector
It appears that the jet is trying to go against the gravity. If that's not the correct direction, then change the sign for gravity value; if positive, change to negative.
If it is supposed to rise upward, like a fountain, then you need to increase the flow rate.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
March 10, 2020, 20:48 |
Rep Power: 7 |
Thanks for the reply.
It’s correct gravity. Gravity in the positive x direction ( right side ). The velocity at the inlet is 2 m/s |
March 11, 2020, 04:12 |
2D axisymmetric
The image you shared is rotated CCW. Is it a 2D axisymmetric case?
In any case, gravity alone will not do the job. You have to also ensure that operating pressure reference location and operating density are defined using correct values. If gravity is in positive x direction, then the minimum value of x in you domain should be the reference location for pressure. Density of gas should be given as operating density.
How to model a co flowing mist jet of air and water impinging on a flat plate with Eu | vikash kumar singh chauha | Fluent Multiphase | 0 | August 28, 2017 02:45 |
help!! water jet impingement heat transfer!(fluent) | erfan.art | Main CFD Forum | 2 | July 12, 2011 15:32 |
help!! water jet impingement heat transfer! | erfan.art | FLUENT | 1 | July 7, 2011 03:40 |
Question about the best way to model water jet impingement on a heated surface | Rockda | FLUENT | 2 | February 27, 2011 10:52 |
Help!!!problems in air jet into water bath | kim | FLUENT | 4 | June 9, 2003 08:04 |
