Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
residuals of bin fraction remains constant
Old   March 10, 2020, 12:26
Default residuals of bin fraction remains constant
mln
melj is on a distinguished road
Hello
I am modeling a multiphase bubble column using Euler-Euler; RSM for turbulence; and PBM. The residuals of bin-fraction appear to be constant after around 30 iterations. Why does this happen? Does this mean that I could run the simulations with lesser no. of iterations per time step? I am using 350 iterations/time step currently.
thank you
melj is offline   Reply With Quote
Old   March 11, 2020, 04:17
Default Residual and Convergence
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Are the residuals low enough? If yes, then it is good.
The idea behind number of iterations per time-step and the size of time-step is to ensure such a value of time-step so that no more than 30 iterations are required for convergence in each time-step. So, 350 iterations is really too high a value. In case the simulation takes more than 30 iterations to converge, reduce the time-step. So, in your case, it is good that it is converging within 30 iterations.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   March 12, 2020, 16:39
mln
I wanted to get the bin fraction residuals below 10^-3. But, it does not go below that and so it does not converge. The value of residual reduces to a constant. I feel that its pointless to let it run for 350 iterations and so rather run it for 50 iterations for every time step.
Or would you suggest to work with the URF?
Old   March 13, 2020, 05:27
Default Residuals
vinerm's Avatar
Vinerm
Computers are dumb, so, they can only consider it 1e-3 if it really is 1e-3. But we can observe it better. So, if it is close to 1e-3, such as 2e-3 or even 3e-3, it is alright. However, if it is at least an order larger, then you can play with URFs as well as gradient limiters. Residuals gets stalled with standard limiters. You can try using cell-to-cell limiters and see if that improves the residuals.
Regards,
Vinerm
Old   March 13, 2020, 18:06
mln
thank you vinerm.
Old   June 17, 2022, 12:47
wu pei peng
cultivate is on a distinguished road
hi,I meet the same question:the residuals of bin fraction is high and it cannot go down with iterations.why?
thanks in advance
cultivate is offline   Reply With Quote
bin fractions, residuals
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Constant Initial Residuals and divergence Gubevens OpenFOAM Running, Solving & CFD 0 May 24, 2016 06:44
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel Mehrez OpenFOAM Running, Solving & CFD 10 May 18, 2016 12:44
Solution not converging, but oscillating residuals around a constant value Irene FLUENT 2 February 7, 2012 12:55
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
