February 14, 2020, 19:07 |
Water filtration
Islam tlidjane
Rep Power: 6 |
Hello everyone
I am new in simulation I need help to simulate water filtration in rotating cylindrical membrane Can anyone help me please? |
February 15, 2020, 07:24 |
Type of filtration
There are multiple types of water filtration. Which one is it that you are interested in?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
February 15, 2020, 08:22 |
Islam tlidjane
Rep Power: 6 |
I want to simulate filtration of water and sand mixture in cylindrical rotating membrane (Taylor-Couette system)
February 15, 2020, 11:32 |
Cylindrical Membrane?
If the membrane is cylindrical, simplest option would be to consider the membrane as a wall. Use DPM for particles and escape condition at the membrane for DPM. Do note if the particle volume fraction is more than 10%, you will have to use dense phase DPM.
February 15, 2020, 18:39 |
Filtration
#5 | |
Islam tlidjane
Rep Power: 6 |
And thank you |
February 16, 2020, 05:28 |
Membrane
It would be expected that you have the answer to that since you are trying to simulate the filtration. For a simple scenario, since it is water and sand, the membrane could be a sieve with size smaller than the sand particles. But then you do not need a rotation; you can just pour the water over the filter and collect the water in a container below. The process could certainly be continuous.
So, the rotational system would only be required if you design a membrane that allows sand particles to pass through but stop the water. The explanation I shared earlier pertains to this system.
Wind shear effect on water level | wouterremmerie | OpenFOAM Pre-Processing | 4 | December 28, 2020 17:01 |
Mass imbalance problem in multiphase water and steam CFX case | Antech | CFX | 1 | October 26, 2020 05:03 |
compressibleInterFoam case – a flat wall air cavity filling up with water | Zeppo | OpenFOAM Running, Solving & CFD | 0 | October 3, 2015 11:01 |
How to model Salinity, density, fresh water & sea water | grayback87 | FLUENT | 3 | December 30, 2014 03:00 |
Liquid water, gaseous water and another gas | Andy | FLUENT | 1 | May 22, 2006 09:51 |
