January 26, 2020, 06:46 |
slug flow
hella
Rep Power: 7 |
Hello everyone,
I'm working on a horizontal air-water confined flow, and I got the slug flow. The problem is when the slug hits the upper part of the channel and blocks the air, this air must return as I think. But it doesn't. Do you have an explanation for this? I'm sure that the air doesn't return because the air BC is velocity inlet, but I really want to understand where did the air goes once a slug blocks its passage to the outlet? I'll be grateful if you help me. Thanks |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
gas-liquid slug flow in horizontal pipe | zainab | FLUENT | 23 | January 26, 2020 06:57 |
You can calculate the pressure drop in two-phase flow? example, slug flow or stratifi | Mechaniker | FLUENT | 0 | December 22, 2014 12:04 |
two phase slug flow | Justion | FLUENT | 4 | June 5, 2014 11:47 |
Slug flow in square channel | PaulC | FLUENT | 0 | December 5, 2005 03:03 |
