2 Phases with same parameters, any diffusion? |
January 14, 2020, 09:25 |
Hi!
I’m struggling with what seems to be a pretty basic problem. I’m simulating a wash out kinetic in a fluidic device, I want to see how phase 1 is replaced by new injected phase 2. Both have the same physics, both of liquid water at the same temperature. My question is now if there is any diffusion? Or did I basically switched those off because I used for both phases the same properties? Kind regards Kai |
January 28, 2020, 10:47 |
Model dependent
Hi
That depends on the model used. if both the fluids belong to same phase as multiple species or components, then by default there is a diffusion coefficient applied. You may set it to very small value. If both fluids are treated as separate phases, then there is no diffusion by default since that would require mass transfer in the phase interaction.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
how to obtain mass diffusion coefficient with UDF? | Weiqiang Liu | FLUENT | 0 | May 28, 2019 13:32 |
How to read multiphase parameters in creatFields from Transportproperties ? | Amirhosseinesh | OpenFOAM Programming & Development | 4 | October 12, 2018 11:28 |
Parameters rhoSimpleFoam | marcus85 | OpenFOAM Pre-Processing | 0 | May 15, 2013 10:36 |
implementation of diffusion coefficients and use of diffusion coefficients | stephan | OpenFOAM Running, Solving & CFD | 0 | February 28, 2010 15:30 |
Numerical diffusion error | Z.Zeng | Main CFD Forum | 8 | October 22, 1999 10:06 |
