Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
UDF for PDE
Old   January 9, 2020, 06:04
Default UDF for PDE
Vinay Chandrakar
chinu007 is on a distinguished road
Hi everyone,
I want to write an UDF for the partial diffusion equation which I have, these PDE contains unsteady, diffusion, convective and source terms. I have no idea how to write a UDF/UDS for this governing equation.
Can anyone helpme with that?
chinu007 is offline   Reply With Quote
Old   January 28, 2020, 10:51
Default No need for UDF
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Hi Vinay
Though I have not seen the equation you have but based on its physical components, i.e., transient, convection, diffusion, and source, you do not require a UDF. You may just enable a UDS in Fluent and that makes the equation available.
UDF would be required, in addition to the UDF, if you want to specify some complicated relation for its source or its diffusion coefficient is affect by turbulence, or if the transient component is treated differently from standard conservation equations.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
Save output of udf in another udf! JuanJoMex FLUENT 0 February 8, 2018 13:43
UDF Compilation Error - Loading Library - COMMON Problem! Help! robtheslob Fluent UDF and Scheme Programming 8 July 24, 2015 01:53
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
