how to find the apparent viscosity of non-Newtonian fluid in fluent? |
mln
Rep Power: 6 ![]() |
Hello
I am trying to model bubble column reactor having a non-Newtonian liquid as primary phase and air. I have used shear dependent non-Newtonian power law model. I want to find the apparent viscosity of the liquid. 1) Would like to know whether the molecular viscosity that Fluent determines is the same as the apparent viscosity. I checked the contour plot of the molecular viscosity for the liquid and the mixture in my simulation. But, I found that the upper and lower limit of the viscosity range for the liquid is always equal to the maximum viscosity that I entered while defining the fluid. Also, the viscosity range for the mixture, however, shows the range I defined initially. That is, mixture viscosity values are giving me results expected for the liquid. I am confused with this result ![]() 2) Even the shear rate (strain rate in fluent) is not within the expected range (i.e, based on the non-Newtonian power law formula). Kindly help. thank you |
bubble column, non-newtonian, viscosity determination |
varying the viscosity of the fluid in a Lattice-Boltzmann simulation | frioual | Main CFD Forum | 0 | April 29, 2019 05:50 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Fluid Solid Interface in Fluent | saisanthoshm88 | FLUENT | 2 | July 17, 2012 05:31 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
