Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
multi-phase flow through porous media
Old   November 21, 2019, 02:23
Default multi-phase flow through porous media
Maharashtra
viko8275 is on a distinguished road
All,
I have been working on multi-phase flow through porous media(which is Demister pad) in my case. The flow is of Ammonia in Vapor phase and oil in liquid phase with volume fractions 0.3416 and 0.6584 respectively.
I am using Eulerian multi-phase model with k-w SST turbulence model.
i have calculated the inertial and viscous resistances for the respective phases and still not getting convergence.
My goal is to find the separation efficiency of the Demister pad.
can anybody help me with this?
Geometry-750mm ID semicircle with 300mm length
viko8275 is offline   Reply With Quote
Old   May 14, 2020, 17:36
roshan
roshanak.rabiee878 is on a distinguished road
Originally Posted by viko8275 View Post
All,
Hi
how did you calculate the resistance coefficient (d (m-2), f(m-1), for each phase separately?
did you use a relative factor to attribute intrinsic value to relative values?
roshanak.rabiee878 is offline   Reply With Quote
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
2Phase flow simulation in Porous Media Ansys Fluent Yaqub FLUENT 0 June 22, 2017 04:46
Porous Media coupled with internal flow Samuel Andrade FLUENT 2 August 26, 2012 10:43
multiphase flow in porous media zhou FLUENT 2 August 9, 2012 08:10
reg Porous two phase flow simulation chittoorreddy STAR-CCM+ 1 December 21, 2009 06:37
