Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Transient Multiphase Flow throught a Nozzle
Old   November 6, 2019, 10:46
Default Transient Multiphase Flow throught a Nozzle
williamhgd
williamhgd is on a distinguished road
Hello, in the case of my internship I have to model the efficiency of a coolant according to the geometry of the nozzle. I started with a simple geometry because I've only been using fluent for 1 month (attached photo 1). My problem is that as soon as the fluid (water) reaches the aluminium plate, the fluid does not spread. However, I have specified the surfaces of the workpiece as walls. For me it should come either from my parameters or from the iso-surface created to model the fluid in 3D. Concerning the iso-surface I took as surfaces the walls of the workpiece and the internal fluid of the domain. Here are the parameters taken to solve this problem (photo 2 and 3).
Thank you for your understanding ! Goodbye !
williamhgd is offline   Reply With Quote
Post-processing of multiphase flow transient analysis koscfd OpenFOAM Post-Processing 1 March 3, 2016 04:49
transient mass transfer in multiphase flow Tensian Fluent UDF and Scheme Programming 0 November 16, 2015 11:39
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat kokoory FLUENT 0 August 17, 2011 03:07
Compressible de Laval Nozzle Flow rw511 CFX 3 May 22, 2011 20:48
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 12:46
