Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Gas Separation on Multiphase tower
Old   November 4, 2019, 23:14
Default Gas Separation on Multiphase tower
Charles
ophshore is on a distinguished road
All,
Good Day. I have a problem that i am trying to solve and i would really appreciate some ideas.
I am new to Ansys Fluent(few months old). I have the problem attached picture. This is a vertical 15m column with two separate vertical sections meshed together with a wall in between as shown
1) Water and Air are injected into the domain at known volume rates. Here i have used "Mass" Inflow as my boundary inlet conditions
2). Water and air leaks into another column which transports vertically to outlet at 4
3) Gas is removed from a Gas cap or gas filled domain section which according to our experiment stays almost constant . This gas section we have been measuring moves 1 or 2mtr at maximum during the experiment. For (3), i have used the "Degassing" boundary outlet
4) This section, we are collecting both water and air into another tank(tank not modelled here), here in my domain i have used a "Pressure" boundary outlet
My problem:
I have created a flow domain, describing the below, the air volume from (3) is nothing compared with our experiments.
According to our experiments, we are injecting about 50,000scf/d of air at (1) and are measuring about 30,000scf/d of air at (3) while the rest goes with the water to (4).
Please does anyone have any ideas on a better method of modelling this ?
ophshore is offline   Reply With Quote
Old   November 5, 2019, 12:14
rupak504's Avatar
Lolita
rupak504 is on a distinguished road
kindly go through this. This might help in deciding the multiphase model.
https://www.afs.enea.it/project/nept...ug/node718.htm
rupak504 is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
UDF to partially block the gas flow at porous screen Bisht Fluent UDF and Scheme Programming 0 February 21, 2018 12:21
Turbulent Separation problem fluidmechanics FLUENT 1 September 7, 2015 14:59
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? EnronZhang STAR-CCM+ 1 December 19, 2013 09:41
multiphase fluid separation in fluent peter FLUENT 0 January 19, 2009 13:20
