November 3, 2019, 11:12 |
simulation of nano fluid with D
maede
hi. i want to simulate Al2o3 - water nano fluid in a 2D canity (1*1)
*Diameter of Al2O3=40nm. so volume of one particle=3.35E-23 m^3 (spherical particle) *if depth of cavity be 1m (set at reference value), volume of cavity should be 1m^3. *for 0.04 volume fraction of nano particle, total volume of nano particle should be : 0.04*volume of cavity=0.01 m^3 *finaly the number of nano particle should be: 0.04/volume of one particle=1.19E+21 my question is how can i set this number of particle in a cavity? |
can not run simulation for body sinusoidal movement between two different fluid zones | M.Hodali | Autodesk Simulation CFD | 0 | December 17, 2018 18:07 |
Weird fluid distribution in the interMixingFoam simulation | HectorLee | OpenFOAM Running, Solving & CFD | 0 | July 11, 2018 10:55 |
Miscible fluid flow simulation | j.patel | Main CFD Forum | 0 | November 6, 2014 05:54 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Expert parameter to stop the fluid flow simulation | KK | CFX | 1 | February 25, 2008 17:29 |
