Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How to input a UDF code for simulaing particle-laden flow
Old   September 10, 2019, 02:23
Default How to input a UDF code for simulaing particle-laden flow
Evan Huang
EvanHuang is on a distinguished road
Hi
I am dealing with the problem simulating a circular cylinder in a wind tunnel with air (carried fluid) and solid particles(dispersed phase), the Reynolds number is around 3900 and I am done with the single-phase(air) part with importing the UDF function for the experiments inlet and boundary conditions to Ansys Fluent 18, but now I want to add three source term for my particles' motion which are momentum, k, and epsilon. So my questions are
1. How should I choose the multiphase model in Fluent, for example, DEM, DPM or ...?
2. How to add source terms to it? and the code?
3. I also want to simulate the adhesion of particles, How to achieve?
4. Is there any examples or code related to my problem that I can consult?
Thank you for helping!
EvanHuang is offline   Reply With Quote
UDF for multicomponent particle vaporization Mohsin Fluent UDF and Scheme Programming 17 January 27, 2021 03:57
Using input parameters (velocity inlet) in UDFs - bad UDF? student_1994 Fluent UDF and Scheme Programming 6 September 14, 2018 21:31
Error code: 126 when loading parallel UDF Coop Fluent UDF and Scheme Programming 0 July 13, 2018 09:33
UDF code help solve reaction rate equation palm oil zirkov Fluent UDF and Scheme Programming 0 February 13, 2017 11:34
write code UDF Fluent solve kinetic reaction rate equation palm oil zirkov FLUENT 0 February 13, 2017 11:16
