Two-phase flow _Problem with phase diameter divergence |
August 21, 2019, 03:16 |
Rep Power: 10 |
Hi All,
I'm modeling a plunging jet of water on the water surface inside a tank (see the image). I ran my model in Eulerian-MFVOF as well as Mixture model within Fluent. I came to the conclusion that the generated air bubbles require to capture the drag force at the interface with primary phase (water) as recommended in some literature. My problem is the convergence since should the value of bubble diameter be increased to a larger value (e.g 2mm) from its default 0.01mm (image) for the secondary phase, the solution abruptly diverges and crushes. I tried to play with the under-relaxation factors and followed some instructions online but no luck. Just to mention, the mesh size is 0.5mm for the water phase and for the air on top set to 2mm. Appreciate for any tip. Update: I realized the Eulerian+MFVOF is more stable compared to Mixture model after increasing the secondary phase diameter to even 4mm. So the simulation is going well even though had some shaky beginning. Last edited by esma; August 21, 2019 at 19:13. |
January 8, 2020, 14:51 |
mfvof truble
Veskov Eugene
Rep Power: 15 |
Try using anisotropic drag, simonin turb. interaction with lim. func., per phase k-w SST, W - cycle pressure, stop criterion for pressure 0.001, another variable 0.01, ILU, agressive coarsening, relaxation coeff 0.2 for all variables, variable timestep from 0.001s to 1e-6 s
divergence in two phase flow | ndtrong | Fluent Multiphase | 1 | November 1, 2016 02:08 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
[multiphase] C_UDMI in DEFINE_PROPERTY for diameter of secondary phase | SJSW | Fluent UDF and Scheme Programming | 1 | December 12, 2015 12:06 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
Importance of Hydraulic Diameter Value for Compressible Flow | RyGuy | FLUENT | 0 | August 6, 2009 10:58 |
