Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
BC for open channel simulation in Fluent
Old   August 17, 2019, 09:17
Question BC for open channel simulation in Fluent
Juan Diego
juandeigo is on a distinguished road
I'm quite new with Fluent, I'm trying to simulate a floating hull using Open Channel with Pressure Inlet and flat Initialization.
I'm not using a symmetry plane.
When looking at the results (image attached) there's a disturbance that originates in the inlet wall and eventually ends in a kind of transverse wave from the right of the inlet wall.
What would be the reason for that? Could it be linked to the mesh sizing (limited as I'm using the student license) or could it be a problem of the set-up?
Thanks!
Juan Diego
juandeigo is offline   Reply With Quote
Old   August 17, 2019, 09:39
Default with symmetry
Juan Diego
Additional info: I'm having the same issue using a symmetry plane (attached image).
Old   September 7, 2019, 12:30
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
did you get solution of problem?
Far is offline   Reply With Quote
fluent, hull, multiphase, open channel, vof
Fuel Spray Simulation - How to go about it using fluent? hadiniesta FLUENT 2 May 26, 2017 03:12
Why OpenFOAM much slower than fluent in NACA0012 simulation (transsonic situation) xucloud77 OpenFOAM 5 October 24, 2016 10:23
Fluent Open Channel Simulation ahammack Fluent Multiphase 0 October 12, 2016 13:58
PEM fuel cell simulation pchoopanya Mesh Generation & Pre-Processing 1 March 1, 2016 00:56
LSR (Land speed record) car simulation on FLUENT Maxime31850 FLUENT 2 May 1, 2013 12:15
