Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
the mass diffusion for two miscible fluids with canstant temperatures t = 30c °
Old   June 25, 2019, 08:45
Default the mass diffusion for two miscible fluids with canstant temperatures t = 30c °
ok
Lynda is on a distinguished road
Re,
here is my theme entitled "flow of miscible gravity current"; that is to say a gravitational current is flow of a fluid within another ambient fluid of different density by a mixing phenomenon (Propagation of the gravity current), driven by a dam break, or by the exhaust accidental gas in the atmosphere or gallery. Gravity currents are also found in the environment such as in snow avalanches, the intrusion on the surface of the sea from river waters at the mouth. My research work to study in this thesis: a flow of a dense fluid (salt water) within a less dense (freshwater) miscible. The control parameters of this study are related to the difference of the density, the diffusion, the viscosity, the height as well as the fraction of the depth of the gravitational current.
(the problem I encountered in mass diffusion under the effect of density difference such as saline fluid density 1200Kg / m3 and soft fluid density 998.20 Kg / m3)
Thank you.
Lynda
Lynda is offline   Reply With Quote
the mass diffusion for two miscible fluids with canstant temperatures t = 30c ° Lynda Fluent Multiphase 0 June 25, 2019 08:35
VoF Model, miscible fluids, mass transfer rate yulu FLUENT 1 March 24, 2018 11:59
VoF Model, miscible fluids, mass transfer rate yulu Fluent Multiphase 0 May 12, 2017 08:48
Mass Diffusion Problem : How to? Rahul CFX 3 October 27, 2008 15:15
mass transfer from fluids to membrane Peter FLUENT 0 August 2, 2002 15:27
