Vitor Braga
Rep Power: 7 ![]() |
In Fluent theory guide I found the following information:
"For the phases with multiple species, the phase shares the same pressure as the other phases, but each species has its own pressure (that is, partial pressure). As a result, the vapor density and the pressure used in Equation 17–488 are the partial density and pressure of the vapor." In my case, I have a liquid phase with two species, and a vapour phase with only one species. I am using the Zwart, Gerber and Belamri cavitation model. For this model, how will the solver calculate the mass transfer? Is there any change in Equation 17-493 (see attachment)? If so, how to calculate the mentioned partial pressure and partial density? Thank you for your consideration. Regards, Vitor |
Multiphase model and species transport | Reginaldo Cotto | FLUENT | 1 | June 6, 2024 04:02 |
How to use Fluent Species to model a gas-solid reaction | obsidianop | FLUENT | 0 | January 17, 2019 17:59 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
About species transport module in fluent | mathcow | FLUENT | 2 | September 10, 2013 14:10 |
Laminar flow in species transport model? | Neha Rao | FLUENT | 7 | February 25, 2006 02:23 |
