Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Problem in Heat Transfer in Inner Tube
Old   June 17, 2019, 06:28
Default Problem in Heat Transfer in Inner Tube
Ali
alikashif is on a distinguished road
Hi,Everyone hope all of you are good in health and doing well. I am using fluent
to heat transfer between two circular tubes.after the completion of simulation I check Results. when i see temperature contour there is nothing change in inner tube but the heat is transfer occurred in mid wall.But In Temperature Contour Color is same from start to end. What do You thinks what's the problem with this why heat transfer did't show in inner tube. I also Attached Temperature contour with Please Aslo check that.
Thanks in advance.
alikashif is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? rogbrito Main CFD Forum 1 February 19, 2019 03:11
Evaporation-Condensation in a porous zone (Heat transfer problem) maximilian-1 Fluent Multiphase 1 August 22, 2018 10:42
fluent conjugate heat transfer problem eling FLUENT 9 October 21, 2017 11:10
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
