June 4, 2019, 07:36 |
Solid/Liquid/Gas Simulations
Camila
Rep Power: 11 |
Hi all,
I am doing multiphase Solid/Liquid/Gas simulations using Fluent (the lateste version:2019 R2). The Liquid is my continuous phase. The solid volume fraction is about 30% and the gas volume fraction is very low. It is like a tank with water, the solids are like a bed at the bottom of the reactor, and the gas would be "created" at the bed of solids. I have been using for the Solid/liquid interaction the Eulerian Granular model. However, as my flow has a very slow upflow velocity, I need to simulate around 300s of flow to obtain decent results. Also, I intend to expand this model to bigger reactors, and to reactors with higher velocities as well. At the moment I am trying to work on improving the solid/liquid simulations only (to have a better model, before I include the gas) The problem: I cannot find a way to simulate the solid/liquid interactions using steady state, so I am using transient. However, it takes a very long time to simulate my case (around 7 weeks). I am using a good computer, with 16 processors and enough RAM. To advance in time I am using a higher time step than it is recommended (0.01s). I wonder, is there a more effective (faster) way of simulating solid/liquid flows (and that also allows to add a 3rd phase later on)? I am considering DEM or DPM simulations as well, but I have never worked with them, so not sure would speed up or make them slower. Any inputs on how to get faster results are appreciated. |
granular flow, multiphase flow |
Confusion choosing between static / transient simulations | TharunSK | CFX | 1 | March 15, 2019 17:53 |
3D simulations OpenFoam running too low(more 1 000 000 elements) Suggestion speed up? | silvai | OpenFOAM Running, Solving & CFD | 4 | April 6, 2017 11:44 |
CFD in Naval Hydrodynamics, Off-Shore and Wave Modelling with OpenFOAM | hjasak | OpenFOAM Announcements from Other Sources | 2 | February 13, 2017 04:59 |
Hardware selection for steady/unsteady incompressible, turbulent and cht simulations | maddalena | OpenFOAM | 2 | July 13, 2011 08:55 |
URANS and Transient Simulations | bob | Main CFD Forum | 0 | October 1, 2003 03:54 |
