Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Standard State enthalpy
Old   May 22, 2019, 14:14
Default Standard State enthalpy
aminhgn is on a distinguished road
I am modeling water and air evaporation. I read that I can use standard state enthalpy to model latent heat. Water vapor and water SSE should be defined somehow the difference between them become latent heat. So, if we consider that the SSE is 43999434 J/Kmol, how should i define this for both of them? and what is the sign of them (negative, positive)?
Thanks,
Amin
aminhgn is offline   Reply With Quote
Old   May 30, 2019, 15:37
vivek
vivek162 is on a distinguished road
Material: water-vapor (fluid)
Property Units Method Value(s)
Density kg/m3 constant 0.02307
Cp (Specific Heat) j/kg-k constant 1911.8
Thermal Conductivity w/m-k constant 0.018433
Viscosity kg/m-s constant 9.7009e-06
Molecular Weight kg/kmol constant 18.01534
Standard State Enthalpy j/kgmol constant 43987714
Reference Temperature k constant 298.15
Thermal Expansion Coefficient 1/k constant 0
Material: water-liquid (fluid)
Density kg/m3 polynomial 717.85 2.3932 -0.00572 2.794e-06
Cp (Specific Heat) j/kg-k constant 4182 Thermal Conductivity w/m-k constant 0.60646
Viscosity kg/m-s constant 0.00089004
Molecular Weight kg/kmol constant 18.0152
Standard State Enthalpy j/kgmol constant 0
Define SSE 0 for water, and 43987714 j/kgmol for vapor. if there is no chemical recation in your simulation case the you can simply define the differece as shown above.
vivek162 is offline   Reply With Quote
Old   June 1, 2019, 01:44
Thank you for your reply. it solved my problem. I have two phases, water, and air, I want to get the heat transfer rate or heat transfer coefficient to calculate the nusselt number. I know we can get for the wall in results but it's not wall right now.
Old   June 3, 2019, 16:38
vivek
Please refer chapter 5 & 6. it will help you to find out the HTC at condenser wall.
"Fadhl, B., 2016. Modelling of the thermal behaviour of a two-phase closed thermosyphon (Doctoral dissertation, Brunel University London)."
Old   June 3, 2019, 16:43
That's my problem I am modeling water and air and the walls are adiabatic and the heat transfer is between air and water. I am using VOF for multiphase. Can you help me about it?
Old   June 3, 2019, 16:47
vivek
so do you want to calculate the heat transfer inside the heat pipe between water and vapor? could you please clear to me what do you want to calculate heat transfer outside at condenser or heat transfer inside the heat pipe?
Old   June 3, 2019, 17:00
I have two parallel plates the water and air are in parallel flow. the mass transfer and heat transfer happens between water and air. I want to calculate the nusselt number. the nusselt number is based on the heat transfer rate and width of two plates, the thermal conductivity of air, bulk temperature and interface temperature.
Old   June 4, 2019, 16:01
vivek
you can solve it using Fluent.
Old   June 4, 2019, 16:06
so can you help how can i get a heat transfer rate of airside by fluent?
Old   June 4, 2019, 16:10
vivek
sure I will.
Old   February 28, 2020, 03:02
Default standard state enthalpy of LNG and BOG phase Transfer
  #11
RAVI KARAN TRIPATHI
xnou is on a distinguished road
Can you help me to choose the fluid property for LNG and BOG phase transfer.
Methane phase transfer will also work. so anyone, help me for methane phase transfer.
xnou is offline   Reply With Quote
Old   April 20, 2021, 12:06
Default Not works(((
  #12
Stepan
NeedHelpPls is on a distinguished road
Hello! I try to simulate evaporation-condensation process in water, but on your SSEs Fluent write: "ERROR: Latent heat cannot be less than zero! Latent Heat: -2.64215e+06"
I dont really understand this behaviour of fluent
NeedHelpPls is offline   Reply With Quote
Old   April 22, 2021, 10:26
Default Bug!
  #13
Stepan
Sorry, it works, but, people, be cafeful! In ANSYS 2021R1 are a lot of bugs. (Problem was solved with duplication of project) The same thing is with editing of polynomial materķal properties in fluent. Use piecewise polynomial with 1 range.
Old   June 2, 2022, 11:19
Przemek
gaza is on a distinguished road
Originally Posted by aminhgn View Post
Thanks,
Amin
In Fluent tutorial on boiling you can find this explanation:
best regards
pblasiak
gaza is offline   Reply With Quote
Old   November 12, 2022, 12:14
Sree Kumaran T
sree kumaran is on a distinguished road
Have u found how to solve that please reply
sree kumaran is offline   Reply With Quote
Old   September 28, 2023, 12:41
Karem Elmahalawy
Karem is on a distinguished road
I have the same exact problem and those numbers of SSE didn't solve it.
Karem is offline   Reply With Quote
Old   September 29, 2023, 08:17
Przemek
you have to change phases (primary and secodnary) - vapour should be primary phase
best regards
pblasiak
Standard state Enthalpy difference of same material shinesli FLUENT 2 April 30, 2016 18:59
Problems about the standard state enthalpy DDDDKKKK FLUENT 0 April 8, 2016 23:37
Solver for transonic flow? Martin Hegedus OpenFOAM Running, Solving & CFD 22 December 16, 2015 05:59
error message cuteapathy CFX 14 March 20, 2012 07:45
Defining Inlet Mixture Enthalpy Munggang FLUENT 0 March 2, 2012 17:50
