Rep Power: 7 ![]() |
I want to simulate a two-phase (gas-liquid) flow airlift reactor with water as the primary phase and bubble as DPM. The bubble coming in from sparger at the bottom of the reactor. Water has zero velocity at initial and doesn't leave the reactor at the end. 1. Should i activate the multiphase model or just go with 1 phase (water) and DPM (bubble)? 2. Since the water velocity initially is zero, can the bubble as a discrete phase agitate the water so that it will circulate? I don't have any clue on that, what i want to get is the residence time and circulation time from bubbles. Any help will be appreciated Thanks |
airlift reactor, dpm, two phase flow |
reactingTwoPhaseEulerFoam - stability of subcooled boiling simulation | Robin.Kamenicky | OpenFOAM Running, Solving & CFD | 20 | September 20, 2021 10:15 |
Creating mixture material for gas dissolved in liquid | richard222 | Fluent Multiphase | 0 | May 7, 2016 13:20 |
Fuel Spray Liquid Penetration in Dpm Fluent | criolla | FLUENT | 0 | August 3, 2015 06:58 |
DPM - do the particles affect the liquid? | Nikhil Dani | FLUENT | 0 | January 1, 2009 11:58 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
