Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Condensation Mass Flow Rate
Old   April 23, 2019, 15:53
Question Condensation Mass Flow Rate
Aseel
Aseel is on a distinguished road
Hello everyone,
I have created a model to estimate the condensation mass flow rate. I used VOF, Energy and K epsilon Models. My model has a velocity inlet for the steam to enter and a pressure outlet. the solution converges. But, the issue is that the mass flow rate for the water liquid is zero! I increased the number of iterations. But, there is no change. I only get the mass flow rate for the mixture or the water vapor.
Please, find the picture of the obtained results.
Does anyone have any idea? or encountered a similar issue.
Thanks in advance.
Aseel is offline   Reply With Quote
Old   April 25, 2019, 14:30
Default Condensation Mass Flow Rate
Melih Meriç
mmntmflx is on a distinguished road
which mass transfer model did you use? Can you define your setup more detailed?
mmntmflx is offline   Reply With Quote
Old   April 28, 2019, 05:08
Aseel
I have used the evaporation-condensation mass transfer model specifically Lee model (I think its the default one).
by the way, it's a 2D CFD model, the initial conditions are at room temperature. the entering steam is at 380 K (above saturation temp). the temperature of the walls is maintained below the Tsat to allow the condensation.
the velocity inlet is about 0.11 m/s .
the backflow total temperature at the outlet is 300 K..
Thank you!
condensation model, fluent, mass flow rate, multiphase flow, multiphase mixture model
boundary condition with pressure AND mass flow rate tsi07 FLUENT 3 April 14, 2022 13:32
Access inlet mass flow value (target mass flow rate) YCarv Fluent UDF and Scheme Programming 2 April 1, 2018 09:09
Calculating mass flow rate at multiphase flows Kuslo187 OpenFOAM Post-Processing 1 August 21, 2015 19:11
mass flow rate in DPM steady tracking Roule FLUENT 4 June 1, 2015 11:44
Mass flow rate sepidecent CFX 0 August 9, 2011 01:15
