April 4, 2019, 03:02 |
UDF interpretation/compilation
Dhiraj Lote
Rep Power: 11 |
Hello all,
I am using fluent 17.2 and 19.2 both. While running simulation I received this message ================================================== ============================ Node 0: Process 18080: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 1: Process 5944: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 2: Process 12788: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 3: Process 17536: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 4: Process 9872: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 5: Process 8620: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 6: Process 13692: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 7: Process 16536: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 8: Process 14584: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 9: Process 12628: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 10: Process 14944: Received signal SIGSEGV. ================================================== ============================ ================================================== ============================ Node 11: Process 4156: Received signal SIGSEGV. ================================================== ============================ MPI Application rank 2 exited before MPI_Finalize() with status 2 The fl process could not be started. I have tried to performed simulations on series and on parallel but it is not working. Again I tried on varying number of processors say from 1 to 12, still it is not working. Do anyone know, what is the problem and what can be the probable solution. Thanks |
udf for one dimensional linear motion based on force | maccheese | Fluent UDF and Scheme Programming | 2 | September 1, 2019 03:18 |
Save output of udf in another udf! | JuanJoMex | FLUENT | 0 | February 8, 2018 13:43 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 01:53 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 05:01 |
