Periodic Multiphase with Different BC for Phases |
March 26, 2019, 09:50 |
Luiz Oliveira
Rep Power: 8 |
Does anyone know if it is possible to set an periodic boundary condition for one phase and for the other set an pressure outlet for example?
I am trying to extract the time-averaged flow of water and at the same time extract an residence-time distributions curve from a certain region of the domain. The problem is that by solving exclusively with a periodic bc I would be re-injecting my tracer that should be advected out. |
March 28, 2019, 17:40 |
Luiz Oliveira
Rep Power: 8 |
I managed to keep the periodic condition without allowing any tracer to come back by simply setting an automatic command each iteration. I would set the initial portion of my channel as a marked region and maintain its concentration as zero.
adapt/mark-inout-hexahedron [Inside] [Mouse Clicks] [x0] [x1] [y0] [y1] [z0] [z1] #marks zones which you can patch solve/patch [domain] [cells] [region] [variable] [value] #patch zones with tracer concentration solve/execute-commands/add-edit [name] [frequency] ["iteration"/"time-step"] ["command"] #adds an automated command to clear the inlet or outlet |
multiphase flow tracer, periodic bc, rtd |
fluent translationally periodic boundary can not be used for multiphase modeling | zhihuawan | FLUENT | 0 | January 18, 2018 01:08 |
Multiphase flow with Periodic Boundary Condition | luludonotcry | Fluent Multiphase | 1 | March 16, 2016 05:51 |
HELP! Periodic Problem | foxer | FLUENT | 1 | June 27, 2012 08:00 |
[ICEM] how to define periodic in icem ? | mingersai | ANSYS Meshing & Geometry | 1 | February 3, 2012 17:46 |
periodic boundary conditions in multiphase model | swarnajay | FLUENT | 1 | July 24, 2009 11:04 |
