Vitor Braga
Rep Power: 7 ![]() |
Hello! So, as far as I know, when the Mixture model is selected for a two-phase flow, Fluent calculates the viscosity of the mixture with the equation:
mu_mixture = alpha_1 * mu_1 + alpha_2 * mu_2. I would like to change the viscosity calculation to more complex models, such as the one proposed by Dukler (1964). Does anyone know how to proceed? What kind of UDF do I need? Where to implement it? I really appreciate any help I can get! Thank you very much. |
reza
did you find how can you solve this problem? if yes, may i ask you please shear it with me? thanks |
Vitor Braga
Yes, I found a solution. You don't need to change the way Fluent calculates the mixture viscosity. You can just change by UDF the viscosity of each phase to represent the viscosity model that you want. Thus, each phase will have the same value of viscosity (calculated based on the specific model that you want to implement), hence when Fluent calculates:
mu_mixture = alpha_1 * mu_1 + alpha_2 * mu_2 the value it obtains is the value of your model, since mu_1 = mu_2 (and alpha_2 = 1 - alpha_1). I'm sorry if I didn't make myself clear... English is not my native language. If you need any clarifications, please, feel free to ask, I'll try to improve my explanation. |
reza
Really thank you, another question: you used same udf for each phase? may i ask you please if you have your udf, share with me please? |
reza
did you use DEFINE_PROFILE for your work? my main question is that can we write UDF as we can write for single-phase after we can implement this UDF for each phase??
Vitor Braga
Yes, I used the same UDF.
This is the UDF: #include"udf.h" #include "math.h" #define mu_phase1 0.004452 #define mu_phase2 1.208e-05 DEFINE_PROPERTY(beatie_whalley,c,t_phase) { real mu_lam; real vof1,vof2; Thread *tc = THREAD_SUPER_THREAD(t_phase); Thread **pt = THREAD_SUB_THREADS(tc); Thread *tp = pt[0]; vof1 = C_VOF(c,tp); vof2 = 1-C_VOF(c,tp); mu_lam = vof2 * mu_phase2 + mu_phase1 * vof1 * (1 + 2.5 * vof2); return mu_lam; } Yes, you use the UDF for single phase in each phase for the viscosity. |
reza
really thanks
reza
Hi, I have a question, I would be grateful if you could help me.
for my problem: VOF_fluid = 0.8 VOF_solid = 0.2 base on your code: vof1 = 0.8 vof2 = 0.2 ???? or vof1 = 0.2 vof2 = 0.8 ??? or if I give my UDF to each phase, automatically VOF is equal to volume fraction of that phase? really thanks for your great help |
#9 |
Vitor Braga
Well, it depends. VOF1 is the primary phase, which you defined in Fluent.
mixture model, multiphase flow, two-phase flow, viscosity model |
What viscosity to use for solid phase in VOF model | redwanamit034 | FLUENT | 0 | June 14, 2017 17:09 |
Using a new implemented viscosity model with simpleFoam | TemC | OpenFOAM Running, Solving & CFD | 6 | March 8, 2017 03:07 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 13:40 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
species transport model or mixture model? | achaokaoyan | Main CFD Forum | 0 | July 10, 2010 10:52 |
