March 8, 2019, 10:52 |
Eulerian Approach for Droplet Impingement
Denis Sotomayor
Rep Power: 11 |
Hello
I have been trying to model droplet impingement through a eulerian-eulerian approach of a flow over a 2D airfoil (2D simulation) in FLUENT, trying to mimic the formulations stated in the paper "Ice Accretion Modeling using an Eulerian Approach for Droplet Impingement " Kim, Dennis, Sankar, equations (1) and (2). I tried to use the Eulerian Multiphase option, as well as setting Air and Water as my Primary and Secondary phases, respectively; setting water droplets of 0.1 mm and using inlet volume fractions of around 1e-6. Obviously, I get results which are not the ones that I am looking for since I have identified some problems which I have to correct, and, for this, I am asking the next questions: 1.- First problem comes from the fact that I have to state that the "Airfoil wall" should trap the Water particles, therefore, act as an "Outlet". Problem is that I have it already set it as a "Wall". How can I set a binary boundary condition to a surface with different behaviors for each phase? 2.- If the previous can be achieved through a UDF, is there a "template" already designed for this specific purpose? 3.- When simulating the 2nd phase, the viscosity of the water is still accounted in the calculation. Is there a way of forcing the viscosity to 0 without getting an error? (same with conductive heat transfer) Thanks for the help beforehand |
Add a "sink term" in the cells near the wall surfaces in Eulerian approach | asal | Fluent UDF and Scheme Programming | 1 | September 11, 2014 16:05 |
modeling atomization using the Eulerian approach | Hossam | FLUENT | 1 | October 4, 2008 07:48 |
whether DEM or Eulerian approach for high solidup | CFDUSERIN | CFX | 1 | April 19, 2007 10:18 |
whether DEM or Eulerian approach for high solidup | CFDUSERIN | Main CFD Forum | 0 | April 19, 2007 06:35 |
lagrangian vs eulerian approach | leopoldo luongo | CFX | 1 | June 19, 2006 11:12 |
