Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Highly viscous (500 Pa.s) fluid flow
Old   March 5, 2019, 01:32
Default Highly viscous (500 Pa.s) fluid flow
Ahmad Ijaz
ahmadijaz is on a distinguished road
Dear Fellows
I am trying to simulate a casting process using VOF model (air and slurry only). Slurry (viscosity = 500 Pa.s) is assumed as a single phase (No liquid-solid).
Can anyone please tell me where i can get the material to perform this simulation?
Initially i used water instead of slurry. Casting pot (assume it a glass) filled successfully with water, when i changed the water with slurry, simulation diverges after few seconds. So i am confused that it is working well with water but when i use slurry it diverges. I guess, it is happening due to high viscosity but i do not know if to take any other measures in the highly dense fluid cfd.
ahmadijaz is offline   Reply With Quote
Old   May 20, 2019, 10:55
Default plese check
raushan kumar
raushan kumar is on a distinguished road
you can directly put your material under set up without any UDF function. also, check your mesh
raushan kumar is offline   Reply With Quote
Old   June 5, 2019, 09:52
Shekhar Singh Tandel
Shekhar Zeus is on a distinguished road
Can you tell me which opensource toolbox or software used, with its details ?
Shekhar Zeus is offline   Reply With Quote
Wrong multiphase flow at rotating interface Sanyo CFX 14 February 7, 2017 18:19
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Newbie to compressible, viscous flow. Advice on approach to problem? bzz77 Main CFD Forum 4 December 4, 2012 08:59
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
laminar viscous flow in a rectangular duct Bastian FLUENT 0 July 2, 2004 09:51
