Display results from only one phase in a multiphase flow |
February 26, 2019, 04:53 |
Eline Hansen
Hi
I am modelling a two-phase(air and water) open channel flow. I am studying the turbulence downstream a river with different obstacles, and I would like to insert an isosurface to observe turbulence behind the obstacles. As there is high turbulence in the air, the isosurface is apparing in the air as well. Do you know if there is any way of only displaying one of the phases in workbench results? This would be very helpful for my countors as well, as it is difficult to find a range which gives a good result in both water and air at the same time, and in some cases the values in the water and air are similar, causing the phases to blend togheter, making it difficult to determine where the results of phase two starts. Regards, Eline |
February 27, 2019, 05:10 |
annan
Rep Power: 10 |
Dear Eline,
Have you tried defining an iso-clip based on volume fraction of one of the phases ? you can actually define a clip to values of water volume fraction between minimum 0.5 and maximum 1, and you can choose this clip afterwards in the surfaces list to plot your contours on. Hope this will help. Good luck, Regards Annan |
February 27, 2019, 06:07 |
#3 | |
Eline Hansen
ansys 19.2, contour, fluent, isosurface, multiphase |
Multiphase flow and Phase change due to heat transferevaporation | haghajani | OpenFOAM Running, Solving & CFD | 88 | February 11, 2020 09:00 |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 09:38 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Multiphase flow in stirred vessel | cwl | STAR-CCM+ | 0 | March 15, 2017 12:54 |
CFX, multiphase flow, boundary condition is only valid for a phase | hellowqy | CFX | 0 | October 12, 2016 07:20 |
