February 17, 2019, 07:48 |
Droplets in pipes
Alexander Yurishchev
Rep Power: 7 |
Hello everybody,
I am trying to run a transient simulation of the motion of water droplets as a result of air flow in pipe. Unfortunately, I get a very blurred interface due to diffusion effects and maybe because of large grid. I would like to know if there is any way to use some dynamic meshing method in order to get finer mesh near the interface between the water and air phases. Thanks a lot. |
[Other] Mesh and simulation two unconnected pipes | pangasio | OpenFOAM Meshing & Mesh Conversion | 1 | October 5, 2018 02:49 |
Sub micron sized droplets in reactingFOAM | Scram_1 | OpenFOAM | 2 | August 23, 2018 16:50 |
Stability and Realibility of microfluidic droplets storage in tube or storage coil | devalvyas | System Analysis | 0 | February 2, 2016 12:49 |
separation of water droplets from vapour using MPPIC Foam | arkadu | OpenFOAM Running, Solving & CFD | 1 | December 16, 2014 03:00 |
cylindrical pipes | Ben | Siemens | 4 | June 16, 2004 12:25 |
