January 31, 2019, 08:36 |
Cavitation in water hydraulic poppet valve
Aja
Rep Power: 15 |
Hi, and paper result:I am simulating a water hydraulic poppet valve in order to investigating cavitation phenomenon in that. Also, I am using a paper for verification of this simulation. Model is 2D, axisymmetric. Mesh is generated by Gambit software. In order to improve the quality of the mesh, the simulated model is divided into three parts(please see the following picture). Part 1 and part 3 are discretized by using map method, and part 2 is discretized by utilizing pave method. According to the paper, The mesh quality of part 2 has a significant effect on the results accuracy due to the high Reynolds number in this part. My model: My mesh: BC is as follows in my work: How can set "Interracial area concentration"? this is defualt value(0.0001). here, the value of diameter is default value. I think that this value should change in this simulation. but How value? Value of pressure contour is good agreement with the paper result. therefore, My result: when i display vapor volume fraction in Ansys Fluent, I see the vapor in the specified part from the following figure. Location of vapor formation in my result is same with that of that in paper results. But I have a problem with value of vapor fraction contour and the value of my result is greater than value of the paper(please see the following pictures) Why does this happen? My result: Paper result: Thanks. |
January 31, 2019, 08:38 |
Aja
Rep Power: 15 |
Magnify the My mesh in part2:
Residuals are as follows: More decrease of residuals is not very effect on the result, especially in vapor volume fraction. According to above picture, IAC (Interfacial area concentration) have not good convergence and this is a problem!!! There is the following BCs in the paper: The inlet pressure is increased gradually to 14 MPa (14 MPa is the maximum pressure that provided by the pump in the experiment), and the outlet pressure is kept at the atmospheric pressure (gauge pressure is zero in this paper) or increased gradually from 0 to 12 MPa. |
February 1, 2019, 06:10 |
Aja
Rep Power: 15 |
No one help?
udf for valve closing a pipe using dynamic mesh | chem engineer | Fluent UDF and Scheme Programming | 2 | May 13, 2017 10:39 |
cavitation problem for a vibrating plate in water | ndabir | FLUENT | 1 | May 9, 2016 21:08 |
Centrifugal Pump Cavitation problem or not. | ismael.s | CFX | 13 | February 27, 2012 09:00 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 08:10 |
