Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
UDF with VOF method to predict evaporation mass/heat flux at vapor-liquid interface
Like Tree3Likes
Old   January 16, 2019, 02:48
Default UDF with VOF method to predict evaporation mass/heat flux at vapor-liquid interface
vidyadhar
vidyadhar is on a distinguished road
Hi Everyone,
Taking the help of online forums, I have managed to write an UDF that predicts evaporation mass/heat flux at the vapor-liquid interface using VOF method of Fluent.The evaporation flux equation is Hertz-Knudsen-Schrage Equation simplified according to Tanasawa's linearization as mentioned in Hardt and Wondra, J.Compt.Physics 227(2008) 5871-5895.
But, I am facing problems in validating this UDF with literature such as Stefan Problem. Stefan problem involves movement of the interface between a superheated vapor and saturated liquid due to the evaporation of liquid; heat being supplied from a hot wall through the vapor phase.
By running the following UDF, the interface is moving but with higher speed than predicted by analytical solution of Stefan problem. I request anyone to help me- if there is any mistake in the UDF code.
#include "udf.h"
#define T_SAT 373.15
/*to store gradient of volume fraction of primary phase, DEFINE_ADJUST macro has been used*/
DEFINE_ADJUST(my_adjust, mixture_domain)
int phase_domain_index=0.;
Thread *t;
Thread **pt;
cell_t c;
Domain *pDomain = DOMAIN_SUB_DOMAIN(mixture_domain,phase_domain_inde x);
Alloc_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_N ULL);
Scalar_Reconstruction(pDomain, SV_VOF,-1,SV_VOF_RG,NULL);
Scalar_Derivatives(pDomain,SV_VOF,-1,SV_VOF_G,SV_VOF_RG,Vof_Deriv_Accumulate);
mp_thread_loop_c (t,mixture_domain,pt)
if (FLUID_THREAD_P(t))
Thread *ppt = pt[phase_domain_index];
begin_c_loop (c,t)
C_UDMI(c,t,0)=NV_MAG(C_VOF_G(c,ppt));
end_c_loop (c,t)
Free_Storage_Vars(pDomain,SV_VOF_RG,SV_VOF_G,SV_NU LL);
/*This macro is used to apply mass and heat exchange between vapor and liquid phases*/
DEFINE_MASS_TRANSFER(liq_gas_source,c,t,from_index ,from_species_index,to_index,to_species_index)
Thread *gas=THREAD_SUB_THREAD(t,to_index);
Thread *liq=THREAD_SUB_THREAD(t,from_index);
real source;
if (C_VOF(c,liq)!=0.0 && C_VOF(c,liq)!=1.0 && C_UDMI(c,t,0)!=0)
source=5.150461258e-05*(C_T(c,t)-T_SAT)*(C_UDMI(c,t,0)); /*mass transfer rate flux = constant X (Ti-Tsat); Ti is interface temperature */
return source;
Thanks in advance!
Vidyadhar
NishantShah likes this.
vidyadhar is offline   Reply With Quote
Old   February 16, 2019, 15:52
Default doesn't fluent already posses boiling model??
sandy
saddy is on a distinguished road
i dont know anything about udf
however, i think fluent does have rpi boiling model
why not use that?
saddy is offline   Reply With Quote
Old   February 20, 2019, 01:27
Mochibaru
mohibanwar is on a distinguished road
Originally Posted by vidyadhar View Post
Hi Everyone,
#include "udf.h"
Thread *t;
Thread **pt;
cell_t c;
begin_c_loop (c,t)
end_c_loop (c,t)
real source;
return source;
Thanks in advance!
Vidyadhar
Hello Vidya dhar,
Are you sure this UDF is working in your problem without any Energy source?
MohammedGhazi and bidax like this.
mohibanwar is offline   Reply With Quote
Old   February 20, 2019, 02:00
vidyadhar
I understand that the macro DEFINE_MASS_TRANSFER will account for mass and energy source terms in the respective equations. In that way, it should estimate energy sources.
However, I could not get the desired result by using the above UDF and I am still working on it.
Thanks & Regards,
Vidyadhar
Old   February 26, 2019, 06:13
Rahul Ruia
ruiarahul is on a distinguished road
Hi Everyone,
#include "udf.h"
Thread *t;
Thread **pt;
cell_t c;
begin_c_loop (c,t)
end_c_loop (c,t)
real source;
return source;
Thanks in advance!
Vidyadhar
you seem to be pretty knowledgeable in multiiphase simulations, can you please help me with simulating capillary effect in a wick region?
ruiarahul is offline   Reply With Quote
Old   February 26, 2019, 06:22
vidyadhar
Hello Rahul,
I have just started learning multiphase flows. Currently I am not fully involved in it. In future I may study them at length.
I do not know about the simulation of capillary effect etc.
You may please take the help of experts in that area.
Thanks & Regards,
Vidyadhar
Old   June 23, 2019, 22:44
Default UDF for condenstion
Soumitra Vadnerkar
soumitra2102 is on a distinguished road
Hi Vidyadhar,
Can this UDF be useful for simulating condensation phenomenon as well?
If not, then can you please suggest me anything?
Fluent's VoF+Evapo-Conden model did not gave me any considerable condensaton volume fraction.
Thanks
-Soumitra
soumitra2102 is offline   Reply With Quote
Old   June 24, 2019, 00:31
vidyadhar
Hello Soumitra,
I think it should be valid for condensation as well.
You may have to slightly modify the UDF to suit the physics of condensation.
Once it is validated with some proven results, you can rely on it.
As of now, it just works. But, it should be validated.
All the best!
vidyadhar
Old   November 4, 2019, 12:23
Question UDF to save the time value when volume fraction in a cell becomes 1
shivam salokhe
sshivam is on a distinguished road
can anyone please guide regarding the UDF that saves the time value for a cell when the volume fraction becomes 1. I am using VOF method.
Thanks
sshivam is offline   Reply With Quote
Old   March 23, 2020, 04:57
Chuang-Yao Zhao
Scaler is on a distinguished road
Hi Everyone,
#include "udf.h"
Thread *t;
Thread **pt;
cell_t c;
begin_c_loop (c,t)
end_c_loop (c,t)
real source;
return source;
Thanks in advance!
Vidyadhar
Hi Vidyadhar,
Have you solved your problem? I am using Tanasawa's model in simulation of falling film evaporation through the similar UDF. But I am not sure the realibility of the calculation of vof gradient or the |alpha|. Because the temperature is too large.
Any suggestion?
Thanks
Scaler is offline   Reply With Quote
Old   March 24, 2020, 00:55
vidyadhar
Hello Zhao,
I think the gradient estimation is correct.
But, I have not validated it yet.
In future I have to work on this.
Thanks
Old   January 1, 2021, 12:08
Default Regarding writing UDF on Boiling flow in Ansys
  #12
Gujarat
NishantShah is on a distinguished road
Hello Sir, Have you solved the problem of UDF for boiling flow analyses. ?
NishantShah is offline   Reply With Quote
Old   January 1, 2021, 12:10
Gujarat
Old   January 2, 2021, 02:32
vidyadhar
Not yet NishantShah ji.
I think there is something to do on how we are running/executing the code in Fluent. At present I am not working on this problem. Sorry.
Old   January 5, 2021, 01:07
Gujarat
Hello sir, You have stored the gradient of volume fraction in C_UDMI(c,t,0). How do you ensure that this gradient value is positive always. ?
My another question is source term in continuity equation is multiply with ((1/rhoV)-(1/rhoL)) and in energy equation it is multiply with (hlv-(Cpv-Cpl)T). (reference paper: M.Magnini et al./IJHMT). So in your UDF, how do you ensure that this source term what you have calculated is mulitply with respective term in continity and energy equation?
Old   January 5, 2021, 02:01
vidyadhar
1. Magnitude of gradient is stored. pls check about NV_MAG in fluent udf manual
2. I have used the simplified equation (Tanasawa model). The evaporation flux equation is Hertz-Knudsen-Schrage Equation simplified according to Tanasawa's linearization as mentioned in Hardt and Wondra, J.Compt.Physics 227(2008) 5871-5895.
Other ref:
https://docs.lib.purdue.edu/cgi/view..._dissertations
https://cpb-us-e2.wpmucdn.com/facult...Phase-2017.pdf
Regards,
Vidyadhar
Old   January 5, 2021, 02:06
vidyadhar
Correction to the original post:
Instead of DEFINE_Mass_Transfer, we should use DEFINE_SOURCE for adding source terms in continuity and energy equations.
Old   January 5, 2021, 03:38
Gujarat
Sir, when I am Interpreting your udf in fluent, I am getting an error in udf. .. "Scalar_Reconstruction: undeclared variable"
I also found one udf in ansys manual for to store the gradient value of volume fraction..
UDMs are often used to store diagnostic values derived from calculated values of a UDS. Below is an
example that shows a technique for plotting the gradient of any flow variable. In this case, the volume
fraction of a phase is loaded into a user scalar. If an iteration is made such that the UDS is not calculated,
the gradients of the scalar will nevertheless be updated without altering the values of the user scalar.
The gradient is then available to be copied into a User Memory variable for displaying.
# include "udf.h"
# define domain_ID 2
DEFINE_ADJUST(adjust_gradient, domain)
Thread *t;
cell_t c;
face_t f;
domain = Get_Domain(domain_ID);
/* Fill UDS with the variable. */
thread_loop_c (t,domain)
begin_c_loop (c,t)
C_UDSI(c,t,0) = C_VOF(c,t);
end_c_loop (c,t)
thread_loop_f (t,domain)
if (THREAD_STORAGE(t,SV_UDS_I(0))!=NULL)
begin_f_loop (f,t)
F_UDSI(f,t,0) = F_VOF(f,t);
end_f_loop (f,t)
DEFINE_ON_DEMAND(store_gradient)
{ Domain *domain;
cell_t c;
Thread *t;
domain=Get_Domain(1);
/* Fill the UDM with magnitude of gradient. */
begin_c_loop (c,t)
C_UDMI(c,t,0) = NV_MAG(C_UDSI_G(c,t,0));
end_c_loop (c,t)
Can we use this code for store the gradient value of volume fraction ?
Old   January 6, 2021, 22:27
vidyadhar
You might not have defined any variable. pls search for the error over internet.
Also please test UDFs (eg. Gradient calculation - given in the first post and as mentioned in Fluent UDF manual) by comparing the results with any standard numerical/experimental results
Old   March 2, 2022, 13:41
Ejaz Ahmed
ejaz8894 is on a distinguished road
Hi Everyone,
#include "udf.h"
Thread *t;
Thread **pt;
cell_t c;
begin_c_loop (c,t)
end_c_loop (c,t)
real source;
return source;
Thanks in advance!
Vidyadhar
Hello vidyadhar, have you been able to validate this UDF? I was looking into the CFD forums to find a way how to implement a "constant" evaporation source term on the vapor-liquid interface with VOF method in Fluent. I think I just need to add a constant in the "source" variable that you declared. But I don't know where exactly should I put this UDF. Can you please guide me how I can use this UDF in Fluent so that the source terms are consistent with continuity, momentum & energy equation? Also, should I add a species transport equation to see the vapor transport in the gas phase?
Thanks in advance for your help!
ejaz8894 is offline   Reply With Quote
evaporation, evaporation-interface, hertz–knudsen equation, stefan problem, udf
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
UDF to propagat VOF interface at a specified speed Johann FLUENT 1 May 27, 2006 12:39
interface reconstruction in Fluent VOF method? daniel FLUENT 0 May 4, 2006 04:46
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
